ASP Pulley + Double Timing Chain Poll
Old 02-27-2003, 11:18 PM
horist's Avatar
Default ASP Pulley + Double Timing Chain Poll
Ok... I've read that an ASP Pulley needs to be ground down the width of the spacer for a double timing chain... and also the 40 degree (or was it 45?) cut needs to be redone
However, seems to be mostly corvette guys... now from what I've read/seen the C5 pulley has a shorter snout than the F-Body snout...
Old 02-27-2003, 11:26 PM
I8COBRA's Avatar
Default Re: ASP Pulley + Double Timing Chain Poll
Mike, you dont have to grind anything down.
