poly motor mounts/ where do spacers go?
Old 02-28-2003, 11:18 AM
highgmc's Avatar
Default poly motor mounts/ where do spacers go?
installing my motor with my homemade poly motor mounts.
which side of the mount do the spacers go on? the front (radiator side) or rear (transmission side)?
Old 02-28-2003, 01:09 PM
ROB'S SS's Avatar
Default Re: poly motor mounts/ where do spacers go?
tranny side on the drivers side mount, and radiator side on the pass. side mount <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 02-28-2003, 01:21 PM
highgmc's Avatar
<img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 02-28-2003, 01:32 PM
Lost Time's Avatar
I just put a poly insert from Energy Susp. in my driver's side mount and I'll be damned if I can figure out where/why you guys used a spacer. Mine fit right into the clamshell, snug as a bug. Everything lined up beautifully. Oh well, I guess I'm just lucky. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 02-28-2003, 07:13 PM
felton316's Avatar
The spacers are not for the insert/clamshell, its for the whole mount as the bolt goes through it mounting it to the chassis. If you looked at the poly mount, it was about 1/4"-3/8" narrower than the rubber mount. The spacers take up the slack, so the motor doesn't move along the long bolt.
