exhaust setup information.? need help pleae
Old 02-28-2003, 09:22 PM
BLASTER's Avatar
Default exhaust setup information.? need help pleae
i am consider an true duel exhaust setup ideally with QTP headers, high flo cats of no cats, dual cut outs, x- pipe and dynomax mufflers. This is much like the system Extreme Torque spoke about in their post. Does anyone know what way most muffler shops will route the pipes? I would love to do it symmetrically straight back, but will probably run into clearence issues. Will they both gather on the passenger side and then seperate again in the back? Any info or advice would be appreciated.
Old 02-28-2003, 09:32 PM
MOBE's Avatar
Default Re: exhaust setup information.? need help pleae
Are you planning on running them all the way out the back or just dumps before the axle? If you are just doing dumps, you may as well ditch the cats and the cutouts. Mine are symmetrical and run down the sides of the torque arm and dump before the axle.
Old 02-28-2003, 09:44 PM
BLASTER's Avatar
All the way out the back. Any complications with that? Rear axle? I'm new at this stuff. Don't want it to be cop calling loud and would like to pass inspection.
Old 02-28-2003, 10:47 PM
2001CamaroGuy's Avatar
Go under the axle tubes (will look like the C4 corvette from the bottom). I did this and it solved all the problems of getting out the back. The pipes will be higher than the muffle (which will be the lowest part) and the rearend will just lightly sit on the pipes (won't press it down....just touch).
Chris
Old 03-03-2003, 07:47 AM
BLASTER's Avatar
Thanks - if you guys can spare any pics, that would be helpful.
