Need part number for ASP crank pulley belt
Old 02-28-2003, 10:24 PM
Back in the staging lane
Beeler422's Avatar
Default Need part number for ASP crank pulley belt
Just the crank pulley, not the alternator pulley. And not the short belt. I lost my regular belt and just have the short belt now. Thanks.
<small>[ February 28, 2003, 10:26 PM: Message edited by: Beeler311 ]</small>
Old 03-01-2003, 07:03 AM
Beeler422's Avatar
Default Re: Need part number for ASP crank pulley belt
Need this ASAP. Thanks.
Old 03-01-2003, 07:45 AM
89ws6formula50's Avatar
crank pulley
12553118
for the belt just call the dealer, they'll give you the number
Old 03-01-2003, 09:07 AM
Lost Time's Avatar
If you can't come up with the correct part# just go outside and throw a piece of string, fishing line, whatever around the path the belt will take. Then just measure it. It'll be in inches, so make it a 3-digit number (i.e. 378 = 37.8", 510 = 51.0", etc.) and add a K6 at the end. That'll be your belt number.
So, if you measure the path to be 62", your belt number will be 620K6.
Old 03-02-2003, 08:23 PM
WILWAXU's Avatar
Gates: K060760
AC: K040378
Dayco: 5060760
AC: 5040378
Old 03-02-2003, 08:40 PM
Rob98Z28's Avatar
For a 98-02 LS1 f-body, the part number for an ASP
crank pulley belt is 11-760K6.
Old 03-31-2003, 12:12 AM
Ragtop 99's Avatar
Useful info. Just found this using search, so I'll bring it to the top. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
