LE2 guys, what are you setting your rev. limiter at and what RPM are you shifting?
Lloyd says peak power is going to be around 6500-6600. I have a stock 4 bolt main short block with 100K miles so I don't want to spin it to high and have a bearing go out. It wil have all new top end (Pro Mags, Hi tech pushrods, CC lifters, etc.) It will only occasionally go near the rev. limiter, but I do want to have it set for max. performance if needed, and was also wondering were is the best shift point? M6 3.45 rear
