Ideal Turbo heads
Old 06-11-2006, 08:02 PM
FormulaFire's Avatar
Default Ideal Turbo heads
I've been doing some research, and I don't want this to turn into some HUGE debate as many of other threads have. Lets put money and all other variables aside. What would the ideal heads be for a 391 LS2 with a T88 turbo?
Old 06-12-2006, 10:41 AM
It has a 4" Bore
Old 06-12-2006, 10:45 AM
camaroextra's Avatar
Ported 718's?
Old 06-12-2006, 10:47 AM
smokinHawk's Avatar
some good ported all-pros
Old 06-12-2006, 10:48 AM
MrDude_1's Avatar
the ideal head would produce zero boost since it poses no intake restriction.
Old 06-12-2006, 01:26 PM
Anybody use ETP 245s?
Old 06-12-2006, 02:30 PM
93formto98T/A's Avatar
I"m thinking about going etp 245 eventually but there are some that think those runners will be too big and cause surging.
Old 06-12-2006, 04:29 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
I'm putting cnc ported AllPro heads on my little 8.25:1 348ci LS6 block. Points to consider:
-Aftermarket heads have thicker deck, better clamping surface
-Some are designed better than stock, and don't break through anywhere, like the roofs of the runners.
I'd go with aftermarket heads if you are trying to make some serious power, but stock ported heads have made 500-900rwhp a number of times. My current 6.0 heads have made 754rwhp.
Old 06-12-2006, 04:35 PM
There Stage 2 ported ls1 heads on the 391 LS2 now... flowing 305cfm @ .500.. I'm just reaching for a little more. I don't know what would be best for a 391 LS2 w/ a 4" bore... I'm looking at a set of All Pros right now PSJ. They flow 332 @ .600. Whatcha think PSJ?
Old 06-12-2006, 09:06 PM
LS1Tech Co-Founder
Better flowing heads = less restriction = more power made on motor = less boost = more total potential = whatever you want to do
Old 06-12-2006, 09:09 PM
Well ofcourse.. but can I do better than that set of All Pros?
Old 06-12-2006, 09:11 PM
LS1Tech Co-Founder
Well, dunno, I'd think a set of equivalent AFR's or ETP's would be just as good.
Old 06-12-2006, 09:44 PM
engineermike's Avatar
Not so. If your heads pose zero restriction, you still want to fill the cylinder at BDC with compressed air. In fact, a fully tuned NA motor can get as much as 3 psi positive pressure in the cylinder at BDC before compression. If your heads and intake are tuned well enough, imagine running 18 psi boost in the plenum, but getting 21 psi pressure in the cylinder!
But back to the topic, Vizard recommends that turbo, supercharged, and nitrous motors increase the exhaust valve size as much as possible. We've been able to fit a 1.625" exhaust valve in Chevy heads without changing the seat.
Mike
Old 06-12-2006, 10:01 PM
turbo'd stang's Avatar
I'm going to using the ET245's on a 396 with an 88. IMO, that would be a really good head.
Old 06-13-2006, 03:20 AM
I was thinking that would do well. I just am not sure how big of a head to go.. It is a larger engine, and I am trying to get all the potential out of it.
Old 06-13-2006, 01:36 PM
LS1Tech Co-Founder
I was originally going to get a set of ETP heads, but they were backed up.
I have a set of heads similar to what Steve & Mike had on their black car.
Old 06-13-2006, 02:11 PM
MrDude_1's Avatar
Mike
ok, zero boost IN THE MANIFOLD... (pressure is always relative anyway...)
and if you want to think about it that way.... i take back my statement anyway... the ideal head would have infinite vacuum, (or absolute vacuum, depending on how you want to think of it) because it would be cramming all air into the cyl.. not wasting it in the head.
Old 06-13-2006, 04:31 PM
Well it would be sort of difficult (actually impossible) to get 20 psig in the cylinder but have -14.7 psig in the intake plenum. If you can design an intake runner/port that can use ram-tuning only to fill a cylinder with 20 psig and leave the plenum totally void of any air mass, then you've really done something.
I think what you're really trying to say is that an ideal head/intake/cam would at minimum get the same pressure in the cylinder at BDC intake as what's in the intake plenum. In other words, if there's 20 psi boost in the plenum, then ideally, you want 20 psi in the cylinder too.
I wonder if we can use ram tuning to achive a greater cylinder pressure than boost pressure??? You can NA, but I'm not sure if we've optimized ports, runners, and cams for the higher density and mass flow rate of a boosted engine.
Mike
Old 06-13-2006, 04:40 PM
ram09's Avatar
If I was you I would use AFR 225 heads for your engine, the 3/4 inch head deck on these puppies guarantees that they arent going to blow under extreme pressure. They run cooler than factory castings because of there greater mass.
Old 06-13-2006, 06:14 PM
mdhmi's Avatar
AFR 225's without a doubt.
