Does an Iron 370 ci sound right for a Turbo?
I am getting a newly forged fully built engine that is a 370 ci. I am not sure, but i am guessing that its an LS2 block. I mean they don't make a 370 LS1, right? Anyways, I hear that the more cubic inch, the more it affects gas mileage. Is that true? It seems like it could be. I mean i am looking to still make my car mostly street legal and friendly. I would guess a 408 iron block would be too much for what my needs are. Plus i plan on using the STS rear mount turbo. I hear that setup works better some how on smaller cubic inch engines. Not sure if that is true or not.
Most importantly, What the hell do i do with the old stock engine once i get the new one installed? I mean what do you guys do with your old block or engine? I almost wouldn't want to part with it so if something happens after a while with the new one, i still have my old one to use. Does that make sense at all? But my mechanic is going to install the engine. Should i ask him to take the stock engine apart to the point where its in pieces that i can carry by hand or should i invest in something that holds an engine or what? I'd really appreciate some insight on this.
Most with turbo's do the 370 iron block. Which means they utilize the block from a 6.0 truck. They'll bore it to 4.03" and use a stock crank. As for the old motor, most either store it somewhere or sell it to offset some of the cost of the new motor. No point in taking a good engine apart if there's no need. A 408 will make more power, but will cost more and may require a bit bigger turbo.
Sell the engine before you take it out so you can show a running engine. Sell it local and tell them when and where to pick it up.
Its hard to answer your questions w/o knowing your goal; 400rwhp, 600rwhp, etc..
Whats your budget like? Its easy to spend alot in a hurry with FI.
