Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Stock 02' Z06 fuel system limits?
Old 06-13-2006, 06:44 PM
slowride's Avatar
Default Stock 02' Z06 fuel system limits?
When running stock injectors what can the stock 02' z06 fuel system support? I plan on upgrading to 30lbsvo injectors, but when will the stock pumps not supply enough fuel?
I suppose I could use the Racetronix hotwire and pump setup or just run my own line to the pump, but is all of this needed when running a heads/cam 450whp car? If I decide to run nitrous (100-150shot) later will I need more pump then?
Old 06-15-2006, 07:26 AM
slowride's Avatar
Any suggestions would be appreciated.
Old 06-15-2006, 08:14 AM
V-seriesTech's Avatar
I think you will be good at around 470 or under on motor.
Your setup will be good with a 100 to a 150 wet shot without the use of an additional fuel source. I would, HIGHLY recommend something anyways.
I have 42's right now, on a stock pump. I do have a racetronix piece, I hope to have in this weekend.
Old 06-15-2006, 10:44 AM
Kraest's Avatar
Futral Motorsports told me that the stock pump is good for 500rwhp with no problems running NA.
Boosted on the other hand....
Mike
Quick Reply: Stock 02' Z06 fuel system limits?
