what spark plug should i use(heat range)?
Old 06-13-2006, 11:57 PM
gr8one99SS's Avatar
Default what spark plug should i use(heat range)?
what plug for 10.8 to 1 compression and 125 shot dry. i get a little pinging on real hot days and was told a colder plug in the summer might help. Is there any truth to this? I currently use tr6 gapped at.035. Please help me out guys.
Old 06-14-2006, 12:09 AM
BADFNZ's Avatar
I would think a TR6 at that gap would almost be ideal for your setup. If you're still getting ping, you can go to a step colder or maybe back the timing off 1-2*.
Old 06-14-2006, 12:19 AM
gr8one99SS's Avatar
thanks . I did pull timing and it worked but today it got hotter and was back? will the colder plug help on the hotter days or do need octane to compensate for the ethonal blend (crap) gas
Old 06-14-2006, 01:06 PM
gr8one99SS's Avatar
ttt....
Old 06-14-2006, 05:48 PM
BADFNZ's Avatar
The 10% ethanol crap we have here in DFW will make you run leaner, so that may be your issue. If you can't run a higher octane, then you might have to retard the timing even more.
Old 06-14-2006, 08:24 PM
gr8one99SS's Avatar
yeah i had them add fuel in the tune when they pulled timing but the temperature keeps climbing. Dam dallas weather
