LT1 guys with 97+ tailights COme in!
Old 06-14-2006, 06:49 PM
1970judge's Avatar
Default LT1 guys with 97+ tailights COme in!
I got the taillights in so how did you guys make it work because the blinker on 96- lt1's are also running lamps on the rear so howd you guys get it done?
Old 06-14-2006, 07:00 PM
Moderator
BizZzatch350's Avatar
Have you looked on CZ28.com, probably a write up on there some where
Old 06-14-2006, 07:19 PM
burnzilla's Avatar
I think the 97+taillights are Fuggin ugly. If I bought a newer Z28, I would look for tailights of a 93-96 in good shape. I have GTS's, so it makes little difference.
Old 06-14-2006, 08:25 PM
TravisA's Avatar
I like the 93-96 better as well.
Old 06-14-2006, 09:26 PM
urbanhunter44's Avatar
dunno, mine came with 97 tail lights
Old 06-15-2006, 09:04 AM
1970judge's Avatar
Well i wasnt asking if they were ugly i was asking how they made it work.
Old 06-15-2006, 01:43 PM
396D1SS's Avatar
It will all plug right in they all use the same connections
Old 06-15-2006, 01:57 PM
1970judge's Avatar
problem is on LT1's teh blinker is also a running lamp meaning it is on all the time when yourheadlight switch is. So on LS!'s they blinker is on constantly.
Old 06-15-2006, 03:22 PM
roadtrip120's Avatar
I had to fix mine so they would work with the 97+ taillights..
You have to buy a ls1 or 97 + tail light harness, then run a wire from your break light switch under your break pedal to one of the extra wires on the new harness.
I fould a write up on camaroz28 or here, its been over a year since i had to do mine, sorry for the lack of detail
B-rad
Quick Reply: LT1 guys with 97+ tailights COme in!
