PLease help
PLease help
I pulled a dash apart to install some guages on the pillar, and to wire up a nitrous kit. I put everything back together, and now for some reason my foglight and rear hatch buttons don't work. They light up when you turn the lights on but the buttons on the little panel don't work. Any ideas...? The battery was out for more then two days, and I had to reprogram my key fob.
Thats weird man. If it lights up...and doesn't work... maybe the switch itself is bad?... otherthen that, check fuses, grounds.
Removeing the dash once myself, not sure what could be wrong. You sure you didn't pull the dash away, and a connector was still plugged in or something?....
Do you want a schematic for it?
The switch lights up, but doesn't work. I went to the fuse block under the hood for the fog light fuses and relays. The relay is getting power, but the fuse isn't. I put in a new fuse to check that, but it still isn't getting power to the fuse. Now I'm lost. I don't want to go to the dealership, you can't trust those guys...
