Topping out w A4
Topping out w A4
I was running on the highway against a 6spd TA, and I happened to run upto 125@6000rpm, I didnt see the rpms drop and the trans didnt seem to be shifting any time soon. I decided to back off rather than tempt fate, it didnt seem like the tach was bouncing yet. Am I just not going into 4th at WOT or does it take longer? Or does the 4spd auto just happen to top out at 125?
The 4 speed auto does not top out at 125. Heck, ive had my lt1 auto past 125 and it was still accelerating farely well. What gear was it in? Was it in 3rd? Could be a number of things. More explanation I think is needed.
quick question, is there a speed limiter on those? my old truck (an 04 sierra) was governed at 100. no matter what you did, it wouldnt go pass 100. once i reprogrammed it, it would go further past it.
Sounds like the same problem I've had for awhile. From the info I've gotten on here, your 2-3 and 3-4 clutch packs are likely burnt up. Your car has 3.23s since it is a WS6. With my 2.73s It shifts to OD (4th) around 135 mph.
Sold The Fun Stuff :(
My car is programmed NOT to shift into OD at full throttle, but when it was stock it would go into OD at WOT no problem. If you can check your tune, then go from there.
i have been up to 150mph+ in my a4. and still was slowly pulling... i do mean slowly....
and at that time i was stock. not even a cutout. i dont remember where is went from 3rd to 4th but i think it was after 125. dont really remember.
i would never shift my 4l60e in od wot, no way. i even have servos and good clutches, that is just asking for trouble, why do you need to go that fast any way. top of third is a 1/4 mile, shut her done!
Top speed on these cars are 160+, probably around 165 or so, juding from the RPM's. I had the speddo peged a couple of times. By the way some of us live life more than a 1/4 mile at the time.
Originally Posted by 05gto60
just curious, why did you do that?
Originally Posted by josh99ta
The 3-4 clutch pack is the first one to blow out, and WOT shifts into OD is one of if not the quickest way to trash the trans. I programmed it that way just in case I forgot. Safety measure.
If you are conserned about parts braking at WOT, maybe you should not be racing. You can either have a race car or a street car. A mix of both is not to much fun, usually gets expensive, and a pain in the butt if you need a ride to work on Monday because you raced (broke) on Sunday.
The calculator was posted guys. With stock tires and 2.73's you top out 3rd gear at 168 mph. With 3.23's you top out 3rd gear at 142 mph. Those numbers should be very close to accurate give or take 5 mph.
Point is that you should have been nowhere near 6000 in 3rd gear @ 125 mph. However if you had 3.73's then 6000 rpm's in 3rd occurs at 123 mph. Are you the cars first owner? Perhaps the gears were upgraded and they "forgot" to mention it.
Of course with 3.73's and 4.10's it's a different story. But this is where you may need to run a bigger tire and spin the motor a little higher to get that extra 3rd gear pull.
But the bottom line is that you never want to go into 4th at WOT unless you actually like burning clutch packs and rebuilds
