callies racemaster crankshaft
I beleive Callies is dis-continuing the LS1 Racemaster series and will be doing a LS1 Dragonslayer crank in 3.625" and 4" strokes. There is little difference in the 2 cranks as the Racemaster is the same crank as the Dragonslayer with a little more finish time on it; The dragonslayers are a little less expensive than the racemasters also.
The crank will handle 1500hp easily.
