02 LS6 out of the box heads with HotCam
These are straight out ofthe box 2002 LS6 heads with the .6mm longer valve stems going on a Ls1 engine with the Hot Cam in it.
Has anybody done this ? if so what size pushrod did you end up going with ?
The stock 7.4 length or maybe a 7.375 to take into account the longer valve stems and the smaller base circle as compared to a stock LS1 camshaft.
