How do you remove Power steering pulley
Old 06-19-2006, 08:09 PM
Tri5Nerd's Avatar
Default How do you remove Power steering pulley
As the title says, do you need a special tool to remove and replace this pulley?
Old 06-19-2006, 08:16 PM
DanO's Avatar
Yup.. you need a power steering pulley puller!
I got one from the local murrays.. but any auto shop/store should have them.
On mine.. to make it have the proper clearance i actually had to grind a slight bit of 2 pieces in the tool.. so if it doesnt fit perfectly.. dont be scared.
Old 06-19-2006, 08:20 PM
Tri5Nerd's Avatar
Default What about installing the pulley?
Do you use the same tool?
Do you think AutoZone rent them?
Old 06-20-2006, 08:31 AM
That's what she said...
TheBlurLS1's Avatar
Autozone should have them, as will any other autoparts store. They will rent you one, but you get all your money back when you bring it back to them.
