Want To Trade For LSx Car
Hi Everyone,
I am looking to possibly trade a combo of several of my cars for an LSx 6-speed Camaro Z28 or SS or Trans Am (will consider others) preferably with a dark leather interior. Car would preferably be black or dark green but would consider all. I have a truck an access to a trailer to deliver and pick up cars involved from almost any distance in the 48 states.
1997 Camaro SS #379. Black w/ gray leather interior. LT1 6-speed. 58,xxx miles. Tires have about 75 % tread left. All power options work. Drive train is in great shape. Pictures in collage are from May 2006 to June 16, 2006. Would be willing to sell for $9,000 OBO.
1990 IROC-Z. Best of 11.66 @ 117.20. Car (everything) has 33,xxx miles. Dark Red Metallic with Gray standard interior. MiniRam L98/700R4. Car is 1 of 1,275 optioned the way it is. L98/G92/J65/U75. I have a large amount of parts to almost completely return the car to stock that goes with the car. Would be willing to sell for $8,500 obo.
Modifications:
Engine:
AFR 190cc Aluminum Cylinder Heads with 7/16" Studs, drilled for EGR and Temp, and Further Porting by Advanced Valve (278cfm / 230cfm @ 0.600")
Lethal EFI Performance Custom Cam by Joe Overton
Blueprinted Comp Cams 987 Springs
Comp Cams Titanium 10º Retainers
Viton Valve Seals
AFR HydraRev Kit
Trick Flow Chromoly 7.200" pushrods
1.6 Competition Cams Pro-Magnum Roller Rockers
Competition Cams 'R' Lifters
Cloyes Hex-A-Just Double Roller Timing Chain
30lb SVO Injectors
TPIS AFPR
Walbro 255ltr/hr fuel pump
Fluidampr Harmonic Balancer
Induction:
Random Technology Ram-Air
Gutted Airbox with K&Ns
BBK 58mm TB
TPIS MiniRam II
Custom Fuel Lines for MiniRam
Exhaust:
Hooker Long Tube SuperComp 1-3/4" headers
Mufflex Y-pipe
Flowmaster Force II 3" Catback
Dynomax UltraFlo welded muffler
Drivetrain:
Genuine GM 3.73 Gears
Auburn PRO Limited Slip Differential
LPW Ultimate Aluminum Rearend Girdle
LPW Axle Tube Brace Kit
Denny's 3" N2O ready shaft (w/ 1350 10-bolt pinion yoke)
Precision Industries Vigilante 3600 stall Torque Converter
B&M SFI Approved Flexplate
B&M Shift Kit
B&M Auxiliary Remote Mount tranny filter
B&M Auxiliary 24,000GVW SuperCooler
B&M Console Megashifter
GM Corvette Servo
GM 0.500/0.296 TV Boost/Intermediate Boost Valve
Derale Starfire Tranny pan
Suspension:
Global West VaraTrac LCA Relocation Brackets
Global West Spherical Bearing / Del-A-Lum Bushing LCAs
Global West Spherical Bearing fully adjustable panhard rod
Global West TS-14 Steering Box Brace
Alston Chassis Welded Subframe connectors
Hotchkis Strut Tower Brace
Sandblasted and Powdercoated stock 36mm Front and 24mm Rear swaybars
Energy Suspension polyurethane swaybar bushings and endlinks
Energy Suspension polyurethane tranny mount
Energy Suspension Engine Mounts
Air Lift airbags in rear springs
Brakes:
Earl's braided SS brake lines
Bendix Titanium pads
Miscellaneous Modifications:
Edelbrock Hi-Flow Water Pump
March Power & Amp 3-Piece Aluminum underdrive pullies
Comp Cams Billet 3-Piece timing cover
MSD 6AL Ignition
MSD SuperCoil
MSD 8.5 wires
MFY Centerbolt Wire looms
Moroso Billet Aluminum Valve Covers
CSI High torque MiniStarter
Dual 2" A-Pillar gauge pod with: Intellitronix Air/Fuel Ratio gauge and Intellitronix Fuel Pressure Gauge
Kenwood head unit with remote 10-Disc changer and Infinity Speakers
Air Conditioner removed
Emissions removed
1991 Z28. Stock as a rock. Mileage is 150,001. Ultra Blue Metallic with Gray deluxe interior. L98/G92/J41. Would be willing to sell for $3,500 obo.
1987 IROC-Z Convertible. Flame Red Metallic with Tan Leather Interior. Mileage is 98,xxx. 1 of less than 744 made. Car has SLP runners, Edelbrock shorty headers, Pro 5.0 shifter and SLP 2 on the left catback exhaust. Mechanically fine. Power locks do not lock all the way. All other power options work. Car is from Wisconsin and Michigan and has rust over the fenders. The metal beneath the rust is still completely solid. The pictures in the collage are from September to November 2005 and car is unchanged. Would be willing to sell for $5,500 obo.
Please PM me with any interest. I have more pictures available.
Thank you in advance.
Modifications:
Engine:
Viton Valve Seals
AFR HydraRev Kit
30lb SVO Injectors
TPIS AFPR
Induction:
BBK 58mm TB
TPIS MiniRam II
Exhaust:
Mufflex Y-pipe
Drivetrain:
B&M Shift Kit
GM Corvette Servo
Suspension:
Brakes:
MSD 6AL Ignition
MSD SuperCoil
MSD 8.5 wires
Emissions removed
