how do you use seafoam?
I was wondering if anyone knew where i could find a writeup on how to use seafoam for the LS1, mainly on how to clean the intake an which vacuum lines to pour it into, etc etc. thanx for any info
Do a search, lots of info. on Seafoam. Here's a link to start with
https://ls1tech.com/forums/showthrea...hlight=seafoam
You can put seafoam in:
1. Brake booster line in order to clean out intake/heads/combustion chambers.
2. In oil to clean out sludge out of oil passages.
3.Gas tank to clean out fuel system.
Use the search or just simply read the back of the can of seafoam.
