Cheapest way to change fan temps?
I'm looking for an (easy) and cheap way to lower the fans temps on my Z28. Don't really want to install a fan swtich, just want to reprogram them on a budget.
Most shops will charge you their minimum, usually an hour's time - probably same price as buying a switch. If you know someone with software they might do it for less.
You could also find someone in your area with HPTuners for your year car. It would only take them a few minutes to change the fan temps. You could probably throw them a few bucks to make it worth their time, but it should still be cheaper than a fan switch or mail order tune.
Kevin
Kevin
