Can I make it?
Can I make it?
Well I have a bet with a friend for $100 dollars first of all. The bet is that I won't see a 7.2xx all season in the 1/8th mile. My best timeslip so far N/A was.
RT .0802
60ft 1.8581
330ft 5.1982
ET @594 7.4351
1/8th ET 7.9302
1/8thMPH 90.88
Previously this was on Nitto Drag radials so there is much improvement ability for the 60ft area. I have recently bought some M/T ET Drag radials so that should help out alittle. Also I have tweaked the suspension some. Recently I have added a 125 wet shot of nitrous also... which I hope will bring my times down to that level. Thanks for the input!
RT .0802
60ft 1.8581
330ft 5.1982
ET @594 7.4351
1/8th ET 7.9302
1/8thMPH 90.88
Originally Posted by Villain281H
Agreed, get the 60 foot down a tenth or 2 and with the juice you should be $100 richer
Good luck!
Derek
Good luck!
Derek
get some skinnies and slicks and ****** red line that bitch out the whole.. u have a strong enough rear end.. if u dont want to do that get some rear control arms and or some kind of traction pak hundred bucks is yours just push it harder u can get a way better time than that 1.8 with a 12 bolt and 4.10's i got a 1.9 on street tires and stock rear suspension 4 g's out the whole
