Anyone remove a C6 bellhousing?
I'm trying to change my clutch out today (on jackstands!) and have everything removed except for the bellhousing on the back of the engine. I've removed all of the bolts, the bellhousing is loose, but it doesn't have enough room to move back to come off. The engine is lowered as far as it will go on the back, still not enough room.
Whatever GM designer did this should have his a$$ kicked. Not only were the bolts nearly impossible to access, but the C6 has a stupid 1-piece bellhousing. The C5 had a two-piece unit, and only the bottom had to come off for clutch swaps.
Arghhh.....
Tony
Arghhh.....
Tony
update: I've learned that the intake manifold needs to be removed, and the engine tilted back as far as it can go until it just touches the firewall.
Only problem is that my intake manifold is currently a shiny Magnacharger. I'll loosen it up and just slide it forward a bit.
Oh yeah, did I mention that changing a clutch on a Corvette on jackstands sucks!!! I'm still sore from yesterday. Won't be doing this again unless I have a lift.
Tony
Tony
BADA BING BADA BOOM!!!!!!
Arghhh.....
Tony
Arghhh.....
Tony
But isn't the satisfaction of knowing you did it yourself worth it?
HAHAHAHAHA!
So when are you getting a lift?
