head stud TQ specs?
TT-TECH Veteran
Well ARP says 65 on all the 15mm and 27 on all the 10mm, but I usually go 80 on the 15 and 30 on the 10 mm though just what I do I have never had a real problem with it due to either the TQ spec or gaskets. Some others will chime in on there procedure though. I go up in 10 lb increments after 50 or so. I let them sit over night and re check them etc...
I would not go much beyond what ARP recommends for tightening specs. They are a high quality fastener and I think ARP would give torque specs that are approaching yield. If you have a good torque wrench I might bump it up 5-10 ft lbs. Otherwise let her be.
I do think for FI it would be wise to re-torque the head bolts are a heat cycle as ARP recommends. This should help counter the setting that will take place.
Originally Posted by Country Boy
On the TQ paper they said that the TQ spec is usually 75% of the fasteners yeild.
