What did I do??
What did I do??
I was autocrossing my 95 z28 the other day and at the end of the course had to make a very quick stop at high revs. As the revs were coming down the motor started to knock. One of my fellow autocrossers said I may have drained the oil to the front of the oil pan and bent a pushrod by collapsing a lifter? Not sure if that is accurate or not. Any adivce on how to procede? What would be the first step to diagnose an engine noise. I seem to have decent oil pressure when running, and I didn't lose any oil after the incident, there was also no smoke. Just a lot of noise. Any advice would be greatly appreciated as I"m a bit of a novice with these cars.
Thanks
Chad
Thanks
Chad
It sounds like more than just a tick. I don't believe I even came close to the rev limiter. The noise can be heard over my exhaust/header combo which is a full SLP exhaust and headers, no cats. So it seems like it could be serious.
So would I be able to find anything out by just taking off the valve covers and checking for a bent pushrod? Or am I better off going at it from underneath, dropping the oil pan etc.
my friends 97 T/A dropped the pick up tube off the pump and every time you would get on the brakes or corner hard it would lose oil pressure. I've known to other people to have this problem with their car to. So the next time my friend was changing the oil I slapped the bottom of the empty oil pan with a rubber mallet and you could hear the pickup bounce up off the bottom.
If I did lean out the oil what is the easiest way to diagnose what the problem is without taking apart my whole motor (e.g. a way to find out how much I have to spend in case I just decide to sell the car the way it sits instead of fixing it which can be VERY expensive.)
