Drag Racing Tech
Harlan wiring?????
Old 06-26-2006, 04:00 PM
1badV6's Avatar
Default Harlan wiring?????
I already have it hooked up and it works fine. I want to make it to were I dont have to hold down a momentary switch. I would like to know how to wire it for one time activation. Press the button once and it stays active until you release the clutch. Thanks
Old 06-26-2006, 04:16 PM
y2khawk's Avatar
gray 2 step wire to the Blue PCM connector, pin 32, gray wire
Old 06-26-2006, 04:34 PM
1badV6's Avatar
Yes I know. Already have that done. Did you read my post. How to make it a one touch activation?
Old 06-26-2006, 06:51 PM
Carbed4thGen's Avatar
I think maybe u hook it up that way with no switch then? I mean ur talking to the man that design it himself LOL
Old 06-26-2006, 09:06 PM
Coal Mining Director
onfire's Avatar
Mine works how you want yours to work (although I use the brake instead of the clutch for an automatic).
White wire to a button.
Gray wire to a normally grounded wire on the clutch switch that opens when you press the clutch down.
To launch, press the clutch down, tap the button once, wot, let the clutch out.
Old 06-27-2006, 01:07 AM
y2khawk's Avatar
That's exactly what I said
you don't have to hold anything if you've got it wired into the clutch. clutch in, tap the button, release clutch, that's it.
Or are you after something else?
