Need some ideas
Need some ideas
Right now i have a TR224 in the car. I want to upgrade now. I've been doing research on which cam will go best w/ my heads. I need your help on which cam i should go with. I'm trying to save as much $ as possible. Here is the specs on my heads
Stage II Jantzer ported heads. with hollow stem valves and sodium filled on the exaust side. VERY nice valves.
The heads flow 296@.570 if I recall correctly. Also the mid lift numbers are strong,
They have REV dual springs/titanium retainers, new stock gm seals & locks. They are GM 241 casting centerbolt heads (the best ones). They were milled .035".
