Will it run ?????
Old 06-30-2006, 03:30 PM
Sartobuilt's Avatar
Default Will it run ?????
Im having my motor built right now. It should be bone in 2 weeks. This is what I had done... LS6 block Std bore, 3.900 crank (374 ci.) M2 Race LS6 ported heads and a Comp cams XER273 cam, lifters, pushrods and rockers. Compression will bee no more than 10.5:1. (we havent seen where its at yet).
Will my car run ok on the stock computer or do I need to tune right away. Also should I get larger Injectors?
It will have a Supermaxx headers and a LS6 Intake and T body.
Thanks for the help.
How about an air dyno number? Im thinking 450 rwhp?????
Old 06-30-2006, 10:43 PM
Sartobuilt's Avatar
anyone?
Old 07-01-2006, 09:47 AM
Sartobuilt's Avatar
Help please
Old 07-01-2006, 10:05 AM
zeekracing's Avatar
I think it should run, but would definitly need a tune asap. Some 28lb or 32lb injectors would help. You should be around that # with a tune.
