overheatin???????
overheatin???????
my temp. guage reads around 190-210 (normal range) but when i stop somewheres it sounds like water is boiling, steam and water start spillin outta the resivore like crazy. i have already replaced my radiator top and my resivore but the problem still persists. today my temp. went up really high. could it b my water pump? this is the first time the temp ready more than 210.
Could be water pump...you are running a mix of coolant and water?...not just pure water? are you checking the level of coolant when it is cold to make sure it has enough?...are your fans working properly?
