Drag Racing Tech
Transmission
Old 07-04-2006, 12:39 AM
HoytVA's Avatar
Default Transmission
I have a t56 stock transmission. I was wondering what kind of transmission I should get for a drag set up or just stick with the t56? Sorry if this is in the wrong section.
Old 07-04-2006, 01:13 AM
1BADAIR's Avatar
drag only a th400.
the t56 is good though
Old 07-04-2006, 08:27 AM
theblur98ss's Avatar
You need to decide what goals you have for the car. If it sees alot of street driving it's hard to beat the 6 speed. It's tough to run good times in one at the track though. I opted to change my 6 speed to a T400. It's alot better at the track but I miss rowing through the gears on the street.
Old 07-04-2006, 09:40 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
I went from a M6 to a turbo 350 and have never looked back.
Coach
Old 07-04-2006, 11:29 AM
GIZMO's Avatar
Unless you are going to make a ton of HP a TH-400 is overkill and will actually kill some performance. If you want a good transmission that will hold up to a lot of passes build a TH-350. If you want to go fast build a TH-200!
In my opinion, you need a low gear set (2.75) in any N/A car.
Good Luck,
Daren
Old 07-04-2006, 07:23 PM
ApacheDrill's Avatar
TH 350 here and love it
