Problem with Harlan 2-Step, anybody else have a similar issue?
I'm starting to have a problem with the 2 step. It was working great 2 weeks ago at the track and after gutting my car for some odd reason it's causing my car to idle rough. When I disconnect it from the coil packs the engine runs just fine. I thought maybe it was me so I reconnected it and the problem persists.
I checked the wiring and the pins and everything seems fine.
Anybody else have this issue?
FWIW this thing has worked flawlessly for 2 years now, probably one of the best mods of have done to the car.
Edit: Just to add, the white and yellow wire aren't even hooked up. The only thing still hooked is the clutch switch wire (grey). I don't see how it would be armed.
Originally Posted by 02SOMWS6
I ran into a simular problem and turns out my harness was too close to my headers and a couple of wires fused together.I separted them and mine was fine. Just figured I would throw that out there, you may have a hole diffeent issue
PM'ed Harlan and he responded. It's been shipped out
Thanks again for taking a look at it Harlan.
