Prostars and spacers, lugnuts?
I am about to order some Prostars off Summit. I want to go wtih 15x10 in the rears, and 15x3.5 for the front. I was reading in the FAQ that spacers are not recommended due to stress. How many of you are using them?
I talked to my buddy and he said its no problem to change out the wheels studs, so I am no longer opposed to doing that. I will order ARP-100-7708 wheel studs for the rears. Should I order them for the fronts as well?
What type of lug nuts will I have to use with these? I plan on daily driving my ZR1's, and then swapping the Prostars when I need to use them, so I am thinking I will need a open end type lug nut, or a longer close ended. What do you guys think? Any part numbers would realy help. thanks
