???Throttle Cable???
Old 07-07-2006, 01:37 PM
Forza13's Avatar
Default ???Throttle Cable???
I'm removing the traction control box in my 02 WS6 and I need to run a single throttle cable. Does anyone know what cable I would need to do that? Part number? and can a 95-96 trans am cable work?
Old 07-07-2006, 01:52 PM
That's what she said...
TheBlurLS1's Avatar
You're going to loose your cruise controll if you do this also. Are you getting rid of it to clean up the engine bay?
I've made a few posts about putting it under the PCM and running the cables by the wire harness and the a/c lines. I would do it myself, but I dont have TCS/ASR.
Old 07-07-2006, 02:11 PM
thunderstruck's Avatar
i think these are the part numbers
98-99, without TCS = 12565559
00-02, without TCS = 12565560
Forza13's Avatar
yeah i want to clean it up. I'm taking out everything ABS, TCS, and the cruise control. Don't need it. I just need the one throttle cable.
Old 07-07-2006, 02:15 PM
Forza13's Avatar
thanks i'm gona check those right now.
Old 07-07-2006, 02:21 PM
Forza13's Avatar
That was the one. $33.11, not too bad. Thanks man
Quick Reply: ???Throttle Cable???
