Will running racegas on a 91 octane tune hurt?
Probably taking the goat to the track tonight and it's supposed to be a scorcher. Would throwing some 100 in the tank have any ill side-affects to the 91 tune? Just looking to supress any heat induced ping. TIA
Cain
Cain
You'd be better to mix it but as long as it's unleaded you should be safe....You'll really only kill your 02's if you're putting around with it on everyday traffic but if you're WOT like it's intended then you should be okay (with leaded)...They also make 02's that are lead safe but then you have to worry about your valve guide seals...Better to stick with the unleaded stuff...I would say run it...You'll be fine...
