WTB ls1 oil pan, alternator, o2 goodies and more
UPDATED needs 7/10-06
Items in red have been purchased and are no longer needed.
I'm converting an vette ls1 for use in a second gen rx7 with t-56 (ls1 was formerly automatic). Looking for the following:
-F-body oil pan w/ low level sensor, windage tray, and pickup tube.
-F-body alternator w/ mounting bracket and hardware.
-AC compressor w/ bracket and hardware
-head gaskets and head bolts (new only, please)
intake/exhaust
-2x passenger side catalytic converters (need both smaller than drivers side)
-4x o2 sensors (front/rear left/right) Front set of o2s purchased with long connectors. I'd like either the rears alone or a set of 4 with normal connectors.
-o2 sims (for use with long tubes/no cats on the track)
-stock f-body intake (need one for CA smog) complete up to TB.
-IAT sensor (intake air temp)
misc bolts
-starter to block
-t56 bellhousing to block
-manual flywheel to crank (new only, please).
Thanks,
Joel
intake/exhaust
misc bolts
-starter to block
Thanks,
Joel
