Headlight
Headlight
I was wondering if I bought the conversion kit from eurolamps can I put SilverStar bulbs in them instead of the ones they give you? If so, then which ones do I need to buy? Thanks a lot.
Copy & Paste Moderator
You can make your own for ~ $25:
https://ls1tech.com/forums/appearance-detailing/527756-ta-headlights.html
I did some searching on here for you about the eurolamp housings:
https://ls1tech.com/forums/showthrea...light=eurolamp
Looks like you should be able to fit SilverStar H7 bulbs in them.
