Map pockets from a Monsoon equipped car
Does anyone know if I can swap in the extended map pockets from a Monsoon equipped Firebird onto the door of a non-Monsoon Firebird? Would they bolt up without any mods, or would I need the whole door panel?
Restricted User
you need the whole door panel. They are actually plastic welded to the door panel, it's not something that's designed to be replacable.
If you were feeling adverturous, you could cut them off of the old door, and then glue and screw then to your panel, but it's easier to just swap the whole door if you can get one.
mike
mike
Yeah. On Monsoon equipped cars, the map pocket extends from the back of the door to the front surrounding the speaker and tweeter. On non-equipped cars, the map pocket ends in the middle of the door.
Monsoon door:
Non-Monsoon Door:
Monsoon door:
Non-Monsoon Door:
