Strange drag brake user inside please...
I have been using these for the last year or so with my stock brake setup. They work great and all, but the problem is the residual pressure. They drag WAAAAAAYYYY too much, and are overheating during a run. Do I need to buy an entire new master cylinder with adjustable residual? I am also still using the stock ABS block. If I ditch that, will that help? I would guess this problem is costing me about .07 to .1 in ET.
I just have them on the rear and they dont drag at all (aerospace on the front), sure the calipers are centered? Matter of fact if I take a wheel off the pads are lose in the rear and the front wheels turn like a 10 speed.. Stock master with power brake booster still.
But the rotors will get red hot after stopping from a 1/4 mile pass, smells like a clutch burning..
Originally Posted by Slow Z28
i'm having the same problems with my wilwoods and the brake pads hanging on the disc. always just through there wasn't enough room. i'll have to take a second look
