broken egr tube on header
Just discovered a broken weld on the egr tube on my passnger side header Figures it has to be the pia one. Just what I wanted to do. The headers again. I need to pull it off and have it fixed. I was thinking about removing my secondary air system at the same time. Good idea?
Well hinesight..lol I hadnt planned on !egr but it just worked out that way. So yea I'll leave the tube off and just have the hole plugged. The good news is maybe, a big maybe, this had something to do with my terrible trap speed. Oh well time to bleed for the car again. Maybe it'll be a good time to do the coil mod as well. But the main thing is if I get rid of the secondary air system that will eliminate a bunch of tubes and hoses from the engine compartment and clean it up a little. Is it a good idea though is the question?
I would keep the catch can since you already have it and yes it can help with the oil in the intake. It isn't really alot of work the hardest part is getting the prep done for cutting the tab in the block... (don't know if 99's have it) you cut a very small peice off looks bigger then it is in the pictures. I just finished it. That !air and !egr have really cleaned up the engine compartment.
