My motor went :(
Old 07-15-2006, 04:09 PM
navymitch12's Avatar
Default My motor went :(
well its done for......sounds like a piston but not 100$ sure untill we get the dam thing out.....i am in a huge hurry because i am up in NY on leave from GA and need to get this thing done asap so i need some sponsers to help me out.....and of course you guys as well
i am looking to stay stock crank(if its ok) and just do forged dished pistons, and forged connecting rods.
what else am i gonna need to buy to get this motor back running....
i am up for ideas i need to start ordering stuff monday morning!
Old 07-15-2006, 04:20 PM
OUTLAWZ RACING's Avatar
DAM I know how the rush can feel. I bet money your crank is still good thats a plus I think for budget wise go with a stock 6.0 Iron or alum block new that will save time from maching your old block if its still good Then take your crank and new rods and pistons to get balance. I seen it done in an hour and have it install in the block with new bearings and all. But ask a sponser who may be loacted near you what size pistons and leanth rods you need that will net you a 370 But I could be wrong Or order a short block 347
Old 07-15-2006, 04:26 PM
trtturbo's Avatar
Mitch, the only pistons I have in stock are 4.030 Wiseco. I do have a set of 6.125 rods with ARP rod bolts in stock and I'll sell them to you cheap.
Old 07-15-2006, 04:31 PM
Boostaholic's Avatar
You will need some good new rings, head gaskets, and balancing rotating assembly, thats assuming your heads and cylinder walls are ok
Old 07-15-2006, 04:44 PM
I need plane tickets ASAP one way flight from IRAQ
MY BAD I just had too
