O2 extensions issue (Pacesetters)
O2 extensions issue, Pacesetters (video)
I got my Pacesetters LTs from SpeedInc, and installed it today. Haven't got my Y-pipe yet... UPS claims they can't find it. Let's see tomorrow.
In this Pacesetters kit I got some white wire, to extend the O2s.
Does the Pacesetter kit involves cutting wires for the O2s?
Anyway I cut the O2s and extended it almost 12" and fitted the O2s and just fired it up for a couple of seconds, steady RPM @ about 1000rpm.
Am I wrong with the O2 extensions in the Pacesetters kit requires cutting the wires??
Finally, my install took about 8-9 hours, and it was easy. Fun to do when you have a lift and the right tools
This is a video on the start-up with open headers
http://videos.streetfire.net/video/5...65957e5559.htm
That's what she said...
Yes those wires and butt-splices are for extending the O2 harnesses. If you did it and it works great, good job. Most people just buy the plug-n-play extensions so they don't have to cut/splice anything. Cutting could become problematic if you don't do it properly.
you'd get a maint req'd light if you had a problem. But if you have an ORY then you will throw codes anyway. The only way to tell is to read the codes when the computer throws em.
