Slow Leak
Old 07-19-2006, 04:59 PM
qwikz28's Avatar
Default Slow Leak
any suggestions? tires have about 1k on them and i bought them as a wheel-tire package from a sponsor so they were premounted and balanced. they leaked from day 1 but are getting progressively worse
Old 07-19-2006, 06:12 PM
TexZ's Avatar
valve stem maybe, take it to discount, shouldn't charge you much. I had the same problem w/ my stockers and it fixed it.
Old 07-19-2006, 07:37 PM
qwikz28's Avatar
hmmm i never thought about the valve stem. good call i'll give that a shot
thanks!
Old 07-19-2006, 07:42 PM
CSA5's Avatar
You could probably have a small nail or something in it but if you want to try the stems first get a spray bottle with some some and water and spray the stems and when you spray them move them side to side to see you any air is hissing out.
Old 07-19-2006, 10:23 PM
GETGONE's Avatar
Also check the core inside the valve stem to make sure it's screwed in tight. If it's loose it will cause it to loose air too. Belle Tire fixes punctures for free if they're in you're area. Just took my tire there to get a nail removed and patched.
Old 07-19-2006, 11:22 PM
qwikz28's Avatar
i'm doubting its a puncture granted the leak started since that tires were brand new. i'm guessing valve stems and i'm just gonna have a local tire shop look at it. thanks for the suggestions guys... much appreciated
