Under axle pipes
Under axle pipes
I am almost positive that I am going to get a true dual setup with a custom y pipe, that goes into two 1 chamber flowmasters, and under the axle. Before the pipes go under teh rear, they will have a flange there so that the pipes can be removed. Will the car be able to be put on a lift without taking th epipes off? This is the only problem that I see with this setup.
Thnaks for the help in advance.
Originally Posted by GET_SOM
I'd advise going dual straight pipes off the collectors instead of goin through a y-pipe
You can make them to fit where they'll clear with it up on a 2-post, but you'll have to do some measurements to see how low the rearend hangs down once it is on a lift. The easiest way would be to have it on a 2-post when running the pipes out the back, or put it on one and take your measurements before going to the muffler shop.
