93-02 door panels
93-02 door panels
I want firebird panels to hold my tweeters. Will any firebird/trans am/formula door panel from 93-02 fit my 98 z28. Any parts need to be kept from the 98 when switching to firebird panels.
Thanks
Thanks
I think those model years should all be the same. You will need to cut out one of the mounting tabs on you door in order to make the Firebird door panels fit flush. A dremel will make quick work of it.
You will see a litte protruding mount within the area I circled in red. That is what needs to be cut out. Don't mind the rest of what I cut out that was for weight reduction.
