i need advice
i need advice
im changing the watr pump on my bird i bought a fail safe thermostat 195 degrees, should i go with a lower one anywhere in between 160 or 180. The fail safe comes only in 195 but if ur termostat brakes is stays open not like others that stays close. Im very confused any your guys expertise advise would be appreciated, also any advice on the water pump. thank you.
