alternator connections LS's & LQ's
Old 07-26-2006, 03:20 PM
chevrev's Avatar
Default alternator connections LS's & LQ's
i am considering using the bracketry setup (balancer, water pump, etc...) from a denali on my LS1. i have a few questions...
1.) will the position of the alternator clear the corvette fuel rail covers?
2.) are the alternator electrical connections the same for the LQ and LS engines?
3.) do you anticipate any other problems that i am overlooking?
thanks,
chevrev
Old 07-26-2006, 05:19 PM
patrick_rodgers's Avatar
No direct knowledge, but you need to get all the pulleys, especially the crank one due to offset dimensions which vary from the Corvette, Camaro, and truck. AC compressor mounting might be different
Old 07-27-2006, 08:12 AM
chevrev's Avatar
thanks,
i have the complete denali setup. does anyone know if the connections on the truck/suburban/denali alternators are the same as the LS1 alternators?
thanks
shad
Old 07-31-2006, 01:29 PM
chevrev's Avatar
Default alternator connections; LS & LQ engines
does anyone know if the electrical connections are the same for the LS and the LQ alternators?
thanks,
chevrev
