Does anyone know the 02 ZO6 cam specs, .006 and .050 numbers, etc...
Old 07-28-2006, 09:06 AM
SideStep's Avatar
Question Does anyone know the 02 ZO6 cam specs, .006 and .050 numbers, etc...
I have searched but cannot find the .006 numbers or the amount of advance (if there is any)...
Old 07-28-2006, 11:50 AM
jrp
SN95 Director
jrp's Avatar
SDPC Part Number: 12565308
Manufacturer: GM Factory Replacement Parts
Advertised Duration Int. : 270
Advertised Duration Exh. : 282
Camshaft Duration @ 0.050" I/E : 204/218
Camshaft Lift I/E : 0.551"/0.541"
Lobe Seperation Angle : 117.5
RPM Range : 2000 - 6200
Camshaft Type : Hydraulic Roller
Old 07-28-2006, 12:08 PM
RedHardSupra's Avatar
any numbers or methods how to translate the duration numbers to 1.8 rocker?
Old 07-28-2006, 12:23 PM
voda1's Avatar
Icl = 120
Old 07-28-2006, 12:32 PM
SideStep's Avatar
Thanks everyone.....
Anyone ever experiment with advancing one of these cams (+2, +4...)....?????
Old 07-28-2006, 02:47 PM
Super Hulk Smash
JakeFusion's Avatar
Why? A peak of 5300 RPM would rock!... You still have really low overlap, an extremely early IVC, and an exhaust bias over TDC if you advance it much past 117.5. All of those things = no power and the inability to carry what power there is anywhere. Yes, off idle torque would be L98+the devil, so it might be good for a 4x4 rock crawler, especially since it's easy on the springs.
Old 07-28-2006, 03:40 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Here is the campro file on it.
Quick Reply: Does anyone know the 02 ZO6 cam specs, .006 and .050 numbers, etc...
