Looking for good alum drive shaft slip yoke.
I need a stock aluminum drive shaft slip yoke. I do not need a shaft. if you have a bent shaft and a good yoke then that would be perfect. I need one without twisted splines, as that is the problem that I have with the current one.
Thank you.
Thank you.
To clear up any confusion, I do not need nor can use the whole driveshaft. It will not fit my application. I am just in need of the slip yoke itself. Thats why I am hoping for someone with a trashed shaft that I can just get the yoke from.
