Is this abnormal wear on my TC? *Pic inside*
Old 07-30-2006, 12:04 AM
Joel_SS's Avatar
Default Is this abnormal wear on my TC? *Pic inside*
I just pulled my TCI SSF3500 and notice the snout of the TC had some wear on it. Is this normal for about 15,000 miles?
Old 07-30-2006, 12:28 AM
FLT
FLT's Avatar
That doesn't look like normal wear to me. Looks like you have a pump bushing that is in need of replacement.
Old 07-30-2006, 10:35 AM
Joel_SS's Avatar
How hard is that tp replace? I have the tranny out right now.
Old 07-30-2006, 11:26 AM
FLT
FLT's Avatar
The pump will have to be removed. It would probably be best to have a transmission shop do it for you. The pump will have to be taken apart, repaired and reassembled. This will require specialty tools. You could also buy a rebuilt pump assembly. We do offer them if you are interested give us a call.
Old 07-30-2006, 11:53 AM
Yank's Avatar
dont forget to get the converter rebuilt, as any debris from the bushing is in the converter and the hub needs replaced
call TCI for that
Old 07-30-2006, 12:05 PM
Joel_SS's Avatar
Thanks guys, Converter is at TCI being re-built
