Forced Induction - STS drill any?
View Full Version : STS drill any?
bobby5
07-30-2006, 10:51 AM
I was looking at buying the STS kit and was wondering if you have to drill the car anywhere to install it. I want to keep it as originial as possible and dont want to be drilling into it. Do you have to buy different injectors and stuff like that?
detroit_903
07-30-2006, 01:07 PM
Injectors, fuel pump, dyno tune -- That's basically all what you will need. Other then a meth or intercooler set-up - if you plan on running over 5psi of boost. It's defently a fun/ awesome kit. I would recommend it to anyone.
SilverSS
07-30-2006, 02:22 PM
The only thing that needs to be drilled is holes for the oil pump mounting. Also you will need to drill and tap a fitting for the oil line by the oil filter. I guess you can get away with strapping the pump down somehow.
trtturbo
07-30-2006, 03:58 PM
Yes, you do have to drill by the oil filter, but that small piece is available by itself, so you can replace it if you remove the turbo.
