are nitto bfg DR 315's wider then other 315's?
Old 07-30-2006, 04:36 PM
Donohue96M6Z28's Avatar
Default are nitto bfg DR 315's wider then other 315's?
I just put some BFG DR's size 315/35/17 on my tt2's. and now the tire sticks out past the fender a tad. are bfg's some of the wider tires? Im thinking nitto's would probably be alot skinnier, right?
Old 07-30-2006, 05:03 PM
SuperSport4life's Avatar
Bfg's are very beefy tires, they have a very thick sidewall. They might run a little wider then nittos but no by much. They are deff beefier than nittos.....
Old 07-30-2006, 05:06 PM
NBMgreg's Avatar
ya i believe nitto's are almost an inch skinnier than the BFG's...heres a pic of them on tt2's:
bigj2717's Avatar
the nittos do run a little skinny and the bfgs run wider than normal 315s
Old 07-30-2006, 10:57 PM
JGKadell's Avatar
it is because the 315 is a measurement in mm of the widest section of the tire, the bulge of the side wall from each side. Therefore not all tires brands have the same footprint. But Yes, BFG tend to run a wider tread. My 285/40/17 BFG KDW, was almost as wide as my Nitto 555R 315/35/17.
Old 07-31-2006, 02:41 PM
the predator's Avatar
got any pics? those are the same wheels and tires im planning on getting real soon, just curious.
Old 07-31-2006, 03:17 PM
ls1mightymouse's Avatar
the BFG's are bigger than they say. Ive had my 295 BFG's next to a set of 315 nitto dr's and they were damn near the same size.
Quick Reply: are nitto bfg DR 315's wider then other 315's?
