New Clutch, 250 Miles, Shifted, POP, Petal on Floor...
Old 08-06-2006, 01:47 PM
Sharpe's Avatar
Unhappy New Clutch, 250 Miles, Shifted, POP, Petal on Floor...
Just installed a new clutch and '02 hydraulics ~250 miles ago. Been taking it easy on it. Wasn't shifting under load, just an easy going 2-3. Heard a pop and the clutch stayed on the floor.
What all could be wrong? Could it be serious or nothing big?
Man I'm bummed out.
Old 08-06-2006, 07:06 PM
Sharpe's Avatar
Search found a post that actually describes the pop: https://ls1tech.com/forums/showthrea...ht=petal+floor
So, might be the return spring, a retainer clip, or I broke the brand new master?
Originally Posted by v8maro
yeah, you can just re-attach that spring. There is also a retainer clip that could have come off, thent he master would have been let loose. He could have also broke the master.
-Steve
Originally Posted by GlennNo50
I don't know if it is the same on these cars but on my 91 RS this happened and it turned out to be a $2 plastic bushing where the pedal is attached.
kinda the same thing here, a metal retainer clip holds the master to the pedal.
Here's another that says it needs to be bled more, but mine isn't "sticking" to the floor, it's dead, loose. It will never come back up.
Old 08-06-2006, 07:11 PM
wrencher
wrencher's Avatar
is it attached to the master at the pedal?
Or is it leaking fluid, blow out a slave cylinder?
Old 08-06-2006, 07:38 PM
Sharpe's Avatar
I had the clutch installed. I drove it back to there and dropped it off. I figure they need to fix it, you know.
But, they didn't have time to look at it or tell me what they thought.
If I would have known of this problem, I would have checked.
Old 08-06-2006, 09:48 PM
deejaydaze's Avatar
update us man
Old 08-10-2006, 10:22 PM
Sharpe's Avatar
Line burst. Bleh. No big deal I guess. Wish I would have had them do the drill mod.
Old 08-13-2006, 01:46 AM
The PAT WS6's Avatar
sounds like ur actuall pedal came undone from the master either that or ur hydrolaulics gave out....
Quick Reply: New Clutch, 250 Miles, Shifted, POP, Petal on Floor...
