Where to buy a larger harmonic balancer puller?
I can't seem to find the balancer puller I need. I typically use the 3 legged puller that you bolt on using the threads on the face of a underdrive pulley. Well when I went to do a March balancer last monday the threads were spaced furthe out. Where can I get a lager 3 legged part?
Originally Posted by sidewayz28
nice... im guna look every where tommorow
*stupid question alert*
if i go up to them with that part number (if their not complete DUMBASSES) they should know what the hell im talking about right
That part number is from Harbor freight
i swear if i knew this damn march pulley was going to be such a pain to remove i would never bought it!!!!!
Call March, I called and just got a msg but have been pretty busy the past few hrs at work. With most dampers it's not the best to pull from the outside edges which is how you use the jaw type. Most likely it would be fine but I prefer to use the other tool to be on the safe side.
